by Kodak Alaris
0
Solution
<100
Summary
Summary
Network-connected document capture that sits at the front edge of an organization's process and integrates directly into a line of business system.
The Kodak INfuse Smart Connected Scanning Solution tackles the most difficult pain points organizations face when onboarding information from paper documents. Automate business processes by seamlessly connecting document capture to UiPath, existing business systems, and the cloud. Benefits include fewer touchpoints and less human error, making the entire information capture process smarter and more efficient.
It's Smart
It's Connected
It's Scalable
Additional accessories available, like Omnikey Smart Card Reader, flatbed for passport capture, bound books, hard/stiff or fragile documents. Kodak Alaris is the industry leader in document capture technology, with over three decades of experience. Combining this experience with the best-in-class RPA solution from UiPath delivers a truly robust, yet scalable document capture and process automation solution.
Features
Features
In addition to the INfuse Smart Connected Scanning device from Kodak Alaris with the same high-quality paper handling and image output you've come to expect, you'll also receive the INfuse Management software that enables full remote management (including workflow design, device configurations and license management).
Additional Information
Dependencies
Infuse Management Software required to operate the INfuse Ax Scanner. Simply connect with an Authorized UiPath Integrator or contact Kodak Alaris for an introduction.
Technical
Updated
March 22, 2022
Works with
Studio: 20.10.2 - 22.10
Support
Phone: +1 (800) 822-1414
Email: DI-Service-Support@kodakalaris.com
Link: https://www.alarisworld.com/solutions/infuse-ax-scanner/supportSoftware Support Kodak Alaris will provide technical consulting for KODAK Alaris INfuse Destination APIs, INfuse Management Application, INfuse Management Software APIs, and EasySetup for INfuse Management Software. Partners will receive up to five hours of technical consulting per year with an annual subscription purchase for INfuse Management Software. Additional technical consultation support can be purchased. After a partner submits a software service request from the Kodak Alaris web portal, the partne
Resources
