MarketplaceStudioSolutionUiPath Accelerator for SAP S/4HANA for Manufacturing
by Internal Labs
0
Solution
Downloads
178
back button
back button
carouselImage0
next button
next button
Summary
Summary
The Accelerator offers a set of pre-built workflows for typical automations in Manufacturing processes for SAP S/4HANA
The UiPath Accelerators for SAP S/4HANA for Manufacturing offer a wide variety of pre-built activities for typical automations that UiPath customers use on top of SAP S/4HANA to automate their Manufacturing processes.
Predefined workflows can be used for both SAP Robotic Process Automation and as an SAP Test Case, thus creating synergies in your automation journey.
They are built for both SAP WinGUI automation as well as native integration via SAP BAPI to ensure that automations are robust, stable and performant.
Use them out of the box to accelerate implementation time of your SAP automation projects.
Sample use case: Managing the Bill of Materials
The Bill of Materials (BoM) is an extremely important artifact in the manufacturing process. It contains information on all the necessary parts to build the final product. It is therefore crucial to carefully but also efficiently create or update a BoM, as errors would prove very costly for the manufacturer. The activities in the Accelerators for Manufacturing such as “Create or change the material BoM” help eliminate errors from manual changes, ensure regulatory compliance and strengthen the supply chain processes.
Content of the package (see more details in flyer enclosed)
Maintain networks (incl. all objects) BAPI, Tcode: CN01)
Сreate or change the Material BOM (BAPI, Tcode: CS01)
Create a planned order (BAPI, Tcode: MD11)
Delete a planned order (BAPI, Tcode: MD16)
Create a production order (BAPI, Tcode: CO01)
Release a production order (BAPI, Tcode: CO05)
Cancel Production Order Confirmation (BAPI, Tcode: CO13)
Enter Confirmation Time Ticket (BAPI, Tcode: CO02)
Maintain project including networks (BAPI, Tcode: CJ20N)
Create Project Definition (BAPI, Tcode: CJ06)
Creation of a routing (BAPI, Tcode: CA01)
Create WBS Elements (BAPI, Tcode: CJ11)
Create purchase info record (WinGUI, Tcode: ME11)
Maintain Quota percentage for the calendar year (WinGUI, Tcode: MEQ1)
4 steps to get started
1. Download the Accelerator from UiPath Marketplace
2. Read the documentation on the Accelerator
3. Install the SAP BAPI Activities package in Studio
4. Build your automations!
Good to know
  • The UiPath Foundation pack for Accelerators for SAP S/4HANA is a prerequisite for the usage of the content above. Do not forget to download it!
  • The transaction codes listed for BAPI are provided as a guidance and do not guarantee the exact same functionality as the listed WinGUI transaction. SAP BAPI in some cases can have more complex structures than transaction code, which includes large number of tables parameters.
  • The package was formerly known as SRC Components for SAP S/4HANA, which was built and delivered by UiPath Japan and it is owned and maintained by the team.
Features
Features
* Flatten the learning curve by using pre-built automations * Easy entry in SAP automation projects * Significantly reduce effort, cost, and errors in automation implementation * Achieve higher automation rate * Adopt best practices for UiPath automation
Additional Information
Dependencies
UiPath Studio 20.10 / UIAutomation Package 20.10 / UiPath SAP BAPI Activities Package 2.2 and above are recommended SAP S/4HANA 1809 or above / SAP WinGUI 7.40 or above
Code Language
Visual Basic
Similar Listings
