by Naresh Kumar
0
Solution
<100
Summary
Summary
Extracting Utilization data from Etisalat Monthly bills using Regex and UiPath PDF Activities.
This workflow can be used to extract the required utilization data from the Etisalat bills. It works as follows:
- Using the mail Activity to access and download the PDF attachment or
- Using Screen Recorder or manually capture the steps from Login to Etisalat website, searching for the account no and until downloading the PDFs for each and every account in your company.
Features
Features
Using this solution you can start right away extracting utilization data from Etisalat bills. Normally it takes a person a minimum of 1 week to manually extract data from PDF in the middle of other tasks they have to do, with this template for example you can extract all the utilization data in less than and 30 minutes for 250 PDFs.
Additional Information
Dependencies
UiPath.PDF.Activites UiPath.Excel.Activities
Code Language
Visual Basic
License & Privacy
Apache
Privacy Terms
Technical
Version
1.0.1Updated
July 26, 2021Works with
Studio: 21.4.4 - 22.10
Certification
Silver Certified
Support
UiPath Community Support
Resources
